head bolt torque ??
Old Jul 9, 2008 | 07:09 AM
farmdawg's Avatar
Default head bolt torque ??
I need some advice/guidance. I am re-doing some work on my car and had to take the heads off, I am using ARP studs for the heads and need to get them torqued properly. I'm out of the ARP assembly lube so I used 30wt oil, what is the recommended torque for FI with studs and 30wt? I remeber reading that ARP had chaged the recommended torque recently, but I can't find the thread anymore. PLEASE HELP???!!!
Old Jul 9, 2008 | 07:30 AM
ls1290's Avatar
Dumb Ass Vette Moderator
Going off the top of my head, I believe it is 5 ft/lb over the amount for ARP lube.
Keith
Old Jul 9, 2008 | 11:40 AM
kbracing96's Avatar
80 ft lbs with ARP lube, 85 ft lbs with oil, I just did mine.
Old Jul 9, 2008 | 01:32 PM
farmdawg's Avatar
Thanks for the help!
Old Jul 12, 2008 | 02:07 PM
bumpin_records's Avatar
thats good information. can you tell me how much to torque the arp harmonic balancer bolt too sense we are on the topic of torque. thanks
Old Jul 12, 2008 | 03:20 PM
ABQ99TA's Avatar
http://www.ls1howto.com/
Old Jul 12, 2008 | 03:28 PM
vettenuts's Avatar
190 lb-ft with ARP lube on the threads, washer and under the head of the bolt. This is installed in step 8 at the point in the installation sequence when the new GM bolt would normally go in. See below:
