90mm Street Warrior LS Intake?
Also as far as the typhoon intake there are actually quie a few people running it here on tech that are very happy with it, as far as I have read its comparable to the LS6 intake, and looks **** on our cars.
And when I think about it this way: Ive had 20 extra hp for the past few months for ~$500 after selling the LS6, and will continue to have even bigger gains on my new setup with it throughout the future, Im happy with my purchase. The FAST is a damn nice piece, and I HIGHLY doubt the SW will outperform or even match it, that is, whenever it is finally released
you should use this time to go learn how to drive or something. maybe you can get your bolt on 02 LS1 a little further outta the 14s. seriously.. lid, catback, and ported TB and youre running 13.8?
im just saying, i dont think this intake is going to be all it's cracked up to be, and you guys may end up pissed off for waiting for it.
Also ALOT of cry babies here and there has been ALOT of post about them running their mouths.
Beleive me, if its ready the Street Warrior would be out on the market.
It might be close, who knows. If it is and it's cheaper, some will buy it. However, the people who want the absolute most out of their setup are still going to go with the fast. This is just how it is. It could also end up being a big flop, like the BBK.
Time will tell
but screw it ill build my own intake manifold out of PVC pipe and a sock as my filter.... 70 extra wheel horse power PROVEN
yeah no
Seems like the R&D department spoke up before the production and QC departments had a chance to test it out. Now they know the market is expecting a peice that will out perform the LS6 and FAST up to 6200 and wants it less than $600.
Something tells me that you may get one, but not both. I could see them releasing two versions, an 'as cast' peice for $600 that is on pace and slightly better than the ls6, and a second, hand ported peice for considerably more.
Give yourselves a lot of credit. I'd bet that 90% of LS1 Tech members have learned how to move air through an engine & have applied that education to their engines. Unless ported, there aren't any of the 7 or 8 intakes currently available that flow 300 CFM even @ .600 lift. The "Street Warrior" would have to steadily flow an amount that would equal 300 CFM @ .550 lift, meaning that the under the curve flow is greater up to that point. As I said, if this is the case, then the air speed used to accomplish this result will be reduced by the area of a higher than stock flowing set-up. So, have confidence in what you have done & let the stock guys benefit from this intake.
I wanted to believe as well, but, after thinking about it have realized that my ported & port matched aluminum Weiand is as good as my engine set-up is gonna get.
Ut Oh....get ready for some heat soak banter.
