Help with cam identification (and specs)! Supposed to be an HPE-S!
Old Jul 10, 2008 | 06:25 PM
DTZ06's Avatar
Question Help with cam identification (and specs)! Supposed to be an HPE-S!
**EDIT**
Appears this is NOT an HPE-S - see new questions below
Howdy Folks!
I bought this cam a L O N G time ago and to keep it short - I'm planning on installing it very soon.
I bought it advertised as an HPE-S grind which I understand is really close to a MS3 or LG GX3. It's in mint condition so if it's the correct part, I should be in good shape (I believe the seller said ~1500 miles).
The box is a Comp Cam but the sticker seems to conflict (and I think it's probably just a box he had lying around).
So on the cam itself, etched right into the end:
LS1 3724R 3731R
HR 114
+4
49440-06
FYI, I tried using the comp cam search and didn't get any hits on any of the numbers. Any help is appreciated (I might give HPE a call if nobody knows - just hated to bug them).
Old Jul 10, 2008 | 07:03 PM
180ls1's Avatar
those numbers look like a comp gring i would just give them a call i am sure they wont mind
Old Jul 10, 2008 | 07:32 PM
ineedatruck's Avatar
the hpe s cam is a standard comp cam grind. thats all i know
Old Jul 10, 2008 | 07:44 PM
LS1MCSS's Avatar
The 3724 and 3731 are the lobe numbers from the comp master lobe catalog.
Attached Thumbnails Help with cam identification (and specs)!  Supposed to be an HPE-S!-lobes.jpg
Old Jul 10, 2008 | 07:48 PM
DTZ06's Avatar
Cool thanks, I see from the catalog those two lobes look like this:
3724R 3724 277 228 149 .346 .076 .062 .519 .554 .588
3731R 3731 291 242 163 .359 .102 .087 .539 .574 .610
The main numbers being a 228/242 duration and a .588/.610 lift (1.7 rockers)
So, umm, what heck [?]
Old Jul 10, 2008 | 09:29 PM
DTZ06's Avatar
Let's say the cam is exactly what the lobe profile indicates (someone on another board mentioned a couple of tuners would do a profiling for like $25) - I wonder how this stick will perform? I mean it's very close to an MS3:
MS3.........237/242 .603/.609
DT CAM....228/242 .588/.610
So a bit less on the intake duration and lift.
This would be used in C5Z06 with stock heads, PRC extreme springs, LT's, CAI, ASP pulley. Side note: I've been thinking it might be worth the extra money for a set of the revised PRC Stage I LS6's (the delta of just springs vs. new heads plus selling my 243's).
Old Jul 11, 2008 | 05:07 AM
Shawn MacAnanny's Avatar
HPE-S cam is 238/242 .608/.612 115+5LSA I had it in my 01 Z06. Put down 465rwhp 422rwtq with ET LS6 heads and a stock LS6 intake, TB, and fuel system.
I still have my cam card for it
32729R/ 3731R HR 115+5
Old Jul 11, 2008 | 08:21 AM
DTZ06's Avatar
Originally Posted by DT
Let's say the cam is exactly what the lobe profile indicates - I wonder how this stick will perform? I mean it's very close to an MS3:
Quoting myself to bump and get some incite specifically into how people think this cam will/would perform! Since I think now it's clear it's not an HPE-S.
Wow, that's pretty stout for a stock LS6 intake/TB (I assumed those were at least ported/port matched?)
Old Jul 11, 2008 | 09:16 PM
DTZ06's Avatar
Still looking for some feedback on the cam:
DT CAM....228/242 .588/.610 114LSA
Ready to schedule my install and/or replace this cam
Old Jul 11, 2008 | 10:55 PM
98RedZone's Avatar
Well, if you can't check from whoever you got it from you could call comp and ask them, although I have heard mixed results from doing that.
I put it in the DC calculator off here and here are some results (assuming stock heads/gaskets)
8.02:1 DCR
44 IVC @.05
7* overlap at .05
I'm not sure if this helps you or not but might get others to chime in. The DCR is a little low I think, but its a pretty big cam. Thee 44* IVC point puts you in the mid 6k range I think. 7* overlap is not too bad of an idle. I think it would make good power with pretty good drivability, but I am in no way an expert, just trying to help you get some more advice.
Old Jul 12, 2008 | 06:59 AM
The TB was ported intake was left alone. I did have my transmission internals micro polished when Rodney@RPM rebuilt it. I'm sure that added 10rwhp or so. It was also on a mustang dyno.
Old Jul 12, 2008 | 02:35 PM
hpe s cam is supposed to be a pretty good all around cam and still make big numbers.
Old Jul 12, 2008 | 05:41 PM
I would go with a different camshaft, it looks like its a custom turbo cam or something.
Old Jul 12, 2008 | 06:21 PM
DTZ06's Avatar
Agreed! Mike N. down in Orlando is doing a killer cam + install special anyway, where it's actually more expensive to provide your own cam!
Think I'll put this up for sale here and get Mike to get me a cam. I appreciate all the info!
