stock main caps max power i will be building an ls1 427, hoping to make 550 n/a and i might run a small shot of nitrous or a small amount of boost like 5 to 8, havent made up my mind, right now i have an 01 ls1 block, im gonna be using arp main studs, so i will be gettin my mains align honed, basicaly will my mains hold up or should i spend the money on some katech mains, dont realy wanna spend more that is necessary |
These motors are 6 bolt mains, I feel as though aftermarket mains arent needed unless you will be making a ridiculous amount of power. |
forgot to mention that i will be running a girdle for the bottom end |
we've built 1000hp ls engine using unpinned stock main caps and 1200hp using pinned stock main caps |
I see you listed a 01 LS1 block. If you use that, it will fail way before a cap will. |
Originally Posted by studderin
(Post 9717951)
Originally Posted by themack56
(Post 9717977)
meaning im good to go right? Thanks, Leo |
© 2024 MH Sub I, LLC dba Internet Brands
