head gasket removal
Old Jul 13, 2008 | 06:43 PM
blkbird's Avatar
Originally Posted by LS1C5Vette
I used a steel wire wheel on a drill and it took 5 mins
x2. I did this to clean off the material off the heads i took off.
Old Jul 13, 2008 | 06:53 PM
slowandrichws6's Avatar
i used a gasket remover, it was like a pad with alot of rubber studs on it and it goes on a die grinder. it took about 3 min and worked like a charm, and dont forget about brake cleaner too
Old Jul 13, 2008 | 08:38 PM
LS1C5Vette's Avatar
You got a pic of what that looks like?
Old Jul 20, 2008 | 02:47 PM
Kurtomac's Avatar
http://www.3mestore.com/scotch-brite...disc-2-in.html
bought one of these...will attach it to my corless drill should work well and not hurt the aluminum
Old Jul 20, 2008 | 08:53 PM
Kurtomac's Avatar
should be good to go with this 3m wheel correct?
Old Jul 21, 2008 | 04:47 AM
vettenuts's Avatar
Not sure, that looks like the one that GM warns you about, have you read the bulletin?
Old Jul 21, 2008 | 06:03 AM
Kurtomac's Avatar
link please
Old Jul 21, 2008 | 08:13 AM
VIPERBLUELX's Avatar
I used a razor blade, then a red scotchbrite pad(by hand), then some brake cleaner on a grease rag. No leaks from my cometics.
