Possible head gasket leak? Please help.
Old Jul 13, 2008 | 04:02 PM
Tyler valo's Avatar
Default Possible head gasket leak? Please help.
I just did a head/cam swap about a week ago, and ever since noticed a faint sweet smell from under the drivers side when ever I get out of the car. Today I noticed water dripping out from where the x-pipe meets the rear pipes. I switched from a graphite gasket to MLS, is it possible I didn't get the surface entirely clean, and it's leaking down the cylinder into the exhaust?
I'm haven't lost any coolant at all, I just notice a very faint sweet smell from mostly under the car. I've never smelt it after opening the hood.
Old Jul 13, 2008 | 04:06 PM
Bloodyoxygen's Avatar
hm well i got a question to.. i need to kno where in the hell my air filter is i just got a k&n filter, but im new to this whole muscle car thing..and i knew this place could help..its a 93 firebird.
Old Jul 13, 2008 | 05:06 PM
LS1C5Vette's Avatar
Well start your own thread and dont jack this one
Old Jul 13, 2008 | 06:06 PM
johnLs1camaro's Avatar
do you have a 98-00 intake manifold???maybe you didnt put the o rings on the coolant crossover and its leaking?? ive done that and my drained behind the engine and that just pisses you off
Old Jul 13, 2008 | 06:07 PM
dyls1's Avatar
do you still have cats and is the water dripping after them if you do?
Old Jul 13, 2008 | 06:43 PM
Tyler valo's Avatar
I think it's just hypochondria. It's running rich, plus the overlap of the cam. The overflow tank hasn't dropped a millimeter in over a week.
Old Jul 13, 2008 | 07:18 PM
DaddySS's Avatar
The slight sweet smell as mentioned can very well be because it's running rich. The water dripping from the exhaust connection is normal - the same water you would see from the tailpipes if you let it sit and idle. If your coolant level isn't going down then you are not leaking coolant. If you are really concerned pull the plugs and do a leak down test but so far you haven't stated anything that should cause you to worry. Not overheating, not blowing pressure from the cap or coolant tank, no bubbles in the coolant while it's running, no coolant in the oil, so far it sounds all good.
