TFS Heads and a MS4?
You might want to look at a custom cam or off the shelf from TFS instead of the MS4. It was designed as max effort for stock heads and whatnot. Trick Flow designed some cams to work very well with the heads. Look at the Stage III cam, 228/230.
I have the TFS 215s and the Stage III cam and love my setup. Do some research and call TEA and see what they can do for you.
