worth porting 853's??
Old Jul 25, 2008 | 01:06 PM
disavowed10's Avatar
Default worth porting 853's??
is it good budget/gain wise?
Old Jul 25, 2008 | 01:13 PM
Torque_SS's Avatar
i dont think so other people might disagree but i sold my stockers and got ls6 light weight sodium filled's off a 04 z06 and aftermarket lunati beehives works great and opens up a broad range on cam choices plus better flowing and improved cc's
Old Jul 25, 2008 | 01:20 PM
Bad Blue WS6's Avatar
any head will be better ported, but dont think they would be as good as the mighty 243;s. Al;though,,i have seen evidence on here that 241's can be ported to acheive higher numbers than 243's....to a certain lift,,the 243's will come out on top with the higher lifts...so really,,you need to know how much your going to be using...
here is a comparison i found in the Chevy High Perfromance book....i have some threads tucked away too with REAL people on here with the same kind of results,,,,people tend to not want to beleive that 241's can be ported that good....but its all in who is doing the porting i guess.
PORTED LS6 PORTED LS1
153 166
202 211
241 244
270 269
280 277
289 283
Old Jul 25, 2008 | 02:22 PM
93redBIRDman's Avatar
Yes 853's can be ported to achieve great numbers. Most on this board have "ported stockers"
Old Jul 25, 2008 | 03:43 PM
hmm.. what about the cost of porting? i mean should i just get the prc stg 1 ls6 heads?? they are only 1k and porting the 853's is prolly gna be about 700 - 900.. i dnt mind paying an extra 200 for some really good heads.. but if the cost of porting was alot cheaper then i would stay with the 853's
Old Jul 25, 2008 | 04:20 PM
if those were my options,,id buy those 243's,,,my porting quotes are averaging around 600, so not to far off from what your gettin..
Old Jul 25, 2008 | 04:50 PM
ss.slp.ls1's Avatar
P&P 243's or 5.3's would be a much better route, and can be had without a huge dent in the budget. Alot of people something like PRC stage 2.5 5.3 heads with great results.
Old Jul 25, 2008 | 09:15 PM
P&P?? hey SLP im a new OC resident.. WATS UP!!
Old Jul 25, 2008 | 10:26 PM
MJD's Avatar
MJD
Depends who ports them. I paid 700 to have mine done. Results in sig. Was it worth doing stock heads instead of buying CNC ls6 heads? I think so.
Old Jul 26, 2008 | 09:33 PM
Jason 98 TA's Avatar
LS1Tech Premium Sponsor
I personally prefer the PRC LS6 heads over porting stock castings, but for lowest money possible porting your stock casting is definately cheapest. We offer the PRC stage 1 porting to stock castings for $600. The PRC LS6 heads sell outright for 1089 though, they move better air & let you sell your stock castings on ebay!!
http://www.texas-speed.com/shop/item...d=649&catid=20
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Old Jul 28, 2008 | 02:24 AM
ss.slp.ls1's Avatar
P&P = Port and Polished.
What's up dude, welcome to OC. If you need any work/mods done let me know.
