Mis-shifted 3rd to 2nd, engine underpowered now?
Agree. Pull the valvecovers and check for bent pushrods (using the roll on glass method) Good chance that is your prob. Damn near everyone's missed a shift at one point. I went for 3rd when I 1st got my Camaro 6 ears ago and hit 1st. Revved to 6900. Wasn't happy. Luckily I didn't do any damage.
Either way, pull the valve covers...check things out. Go from there. Good luck
The reason people got on your *** is because your post gave us the impression that
1) You are a ******** that is jumping down a newbs throat w/o being provoked
2) You don't really know what you are talking about
Unfortunately both characteristics are things that this site trys to avoid. Being a ******** and flamming newbs for making common mistakes is bad because it discourages them from asking questions (which is sorta the point of this site). Also, making suggestions that are based on an inadequate knowledge base lowers the aggregate quality of the feedback people recieve on this site. Please don't be offended by this, but keep it in mind in future posts.
I bent 4 valves(2 intake, 2 exhaust) my stock pushrods wernt even bent but i replaced them too.
I had the heads rebuilt by a local shop for like 200 with 4 new valves and I had it fixed in 2 days including turn arround time(It was my DD)
first of all, i dont know why you would be flogging it like that after missing a shift and noticing something wrong.
pull the valve covers and check for bent pushrods, and any other problem.............naw. forget that, go ahead and pull the intake, accessories and heads. cause your gonna need some work.
one more thing.......learn to drive.
First I already had upgraded dual springs and hardened pushrods, seeing 7k pegged on the tachometer was painful to see though.
Second, I bought heads weeks before this mistake so while it drives fine and still has plenty of power, I expect to see an eyelash.
Best of luck to you.
