Looking for the best of the best heads
Old Jul 28, 2008 | 12:07 AM
Paint_It_Black's Avatar
Originally Posted by BigKap94z
I think the T4P 243's are a great choice. I will have dyno results for those in a few weeks. Larry Meaux would be an excellent choice as well. Cartek stuff Runs very well too.
I'd be very interested in your results. Please send me a PM when you get the tune down and some numbers.
Old Jul 28, 2008 | 12:10 AM
Tekhombre's Avatar
Originally Posted by Paint_It_Black
243 castings or aftermarket castings, and who should they be sent to for port work?
We port the 243s and have great results with them, we also like the TFS heads 215 - 235 depending on the application. They are great out of the box but there is room for improvements.
Julio
Old Jul 28, 2008 | 04:58 PM
BigKap94z's Avatar
No problem I'll be sure to do that!
Old Jul 28, 2008 | 10:48 PM
SOMbitch's Avatar
I have talked to Bret, he doesn't recommend the Darts for a stock bore. He recommends the 243's that Joe Mendelis designed the port for. They are a bit pricey, but I am willing to spend when the product delivers. These heads have been on championship cars, so I am going with his heads/cam package, prob solid roller, and possibly setting up a vic jr intake as well. Just wanted to make a post and see if there were others I have not considered.
Good info. Thanks
Old Jul 29, 2008 | 10:12 AM
Brian Tooley Racing's Avatar
The TFS heads might be great, but I don't know who Vengeance had design the port they CNC so I am not considering them. I hear the newer CNC version ET is releasing on their TFS heads is supposed to be really good, but I haven't seen any results on those. I know the guy holding the 9.90 stock cube H/C record was using AFR's, and I don't see any TFS results better than mid 10's.
RobZ has the C5 Z06 H/C record and has run 10.22 @ 133.5 with his TFS 215’s we did for him, hyd roller cam and pump gas. It looks like the others who are faster either have autos with 5000 stall and are 100 lbs lighter, or are have a M6 and are 100-400 lbs lighter.
https://ls1tech.com/forums/dynamometer-results-comparisons/904451-new-performance-results-346-h-c.html Post #36
A comparable flowing 243 casting will be larger than the TFS 215. Don't get caught up in high lift airflow, it just isn't that important. We've made 2hp/ cu in with heads that stalled at .600" and had .700" cams. The airflow at .300"-.500" is where the power is, even if your running .700" If you go .800" lift then start looking at the .400"-.600", if you go .900" lift then start looking at the .500"-.700"
BTW, all of the TFS/TEA CNC ported castings, including Vengeance heads, are all the same CNC program, the difference is in the details.
Old Jul 30, 2008 | 08:55 AM
ScreaminDemon's Avatar
When I'm done building this thing I want your "Logo" down both sides of my vette Brian!!!!!!!! I lost the email add you gave me for those pics, can you resend it?
davidmoseley22@yahoo.com
Old Jul 30, 2008 | 02:42 PM
transAm-98's Avatar
TEA/TFS heads get my vote!!
Old Jul 31, 2008 | 08:34 AM
Ron@Vengeance's Avatar
Just to clarify for you guys.... The TFS port was designed by Brian Tooley of TEA/TrickFlow.... We had nothing to do with the design of the TrickFlow head other than some preliminary testing. The TFS heads have proven to be one of the best heads on the market time and time again by MANY different shops AND individual customers. Im not saying they are the only choice, but they should definately be in the top 3.......
Old Jul 31, 2008 | 08:43 AM
Joey@Tick's Avatar
LS1TECH Sponsor
We've been extremely impressed with all the Trick Flow offerings for these LSx cars thusfar! In fact, I'll be ordering a set today to go on a customer's car - hoping for 500rwhp.
Brian and Mike over at TEA are definitely two of the most knowledgeable guys in this industry.
