installing cam, top dead center?
Old Jul 27, 2008 | 08:52 PM
themack56's Avatar
Exclamation installing cam, top dead center?
well, im installing a cam in next week, with heads, i was wondering when i take off the heads and the cam, when im putting the timing chain back on and aligning the dots, should the #1 piston be top dead center, meaning when the dots are aligned so should the piston be top dead center?
Old Jul 27, 2008 | 08:56 PM
firehawkzach's Avatar
Yes, I just did this yesterday make sure the dots are aligned and when the dot on the crank gear is at 12:00 you should be at TDC cylinder #1. Just be absolutely sure to get those dots as perfect as possible.
Old Jul 27, 2008 | 09:04 PM
themack56's Avatar
thnx alot
