Is BIG power possible without flycutting?
Old Jul 28, 2008 | 02:53 AM
matts22's Avatar
Default Is BIG power possible without flycutting?
I've been looking into heads/cam setups for quite awhile and I've spent countless hours reading the forums. It seems that everyone that makes BIG power on a stock bottom end N/A LS1 has flycut their pistons because it is almost required to have high compression and a proper cam profile (valve events, big duration, etc.). If possible, I'd like to make this kind of power (480+ rwhp) without having to flycut.
So back to the thread title: Is BIG power possible without flycutting?
If it is possible, what heads/cam setup are you using?
Old Jul 28, 2008 | 08:00 AM
The Alchemist's Avatar
UNDER PRESSURE MOD
I guess it's possible, but just like you said, the equation requires a big cam and high compression. To get high dynamic compression requires the heads to be milled, which then pushes the valves even closer to the pistons.
I'm guessing one way around flycutting would be to have the combustion chambers welded like PRC does (I think that's who does it). But I'd still measure piston to valve clearance with a big cam.
Old Jul 28, 2008 | 11:43 AM
Marc 85Z28's Avatar
You can make that kind of power without clearancing the pistons, but it won't be cheap and it will be on the ragged edge of safe PTV valve clearance. Patriot welds the chambers to achieve better compression, but you'll never make any power with them. The only way you're going to get the compression you NEED with a big cam and piston clearance is an aftermarket head with altered valve angles, like ETP or TrickFlow.
Old Jul 29, 2008 | 12:02 PM
matts22's Avatar
Everyone else agree?
Old Jul 29, 2008 | 01:12 PM
UNDER PRESSURE MOD
I almost forgot about going with a head like TFS. Have it milled to a 60cc chamber to get the compression back up, then run a cam in the 228/236 range and you should be in the mid to high 400s without having to cut the pistons.
Old Aug 2, 2008 | 03:45 PM
jshelton2006's Avatar
I'm running an MS4 on 111 LSA with TEA TFS 215s milled to 59cc chambers. I planned on flycutting but didn't have to. I have .095" intake and .090" exhaust PTV clearance. really surprised me, the 13* valve angles help a lot with clearance. and I should be over 480 rwhp with my setup...hope this helps you.
Old Aug 3, 2008 | 10:08 AM
SOMbitch's Avatar
Very nice setup but....
TFS + aftermarket rockers = $2800
Flycut = $250
Depends what you want spend and granted the TFS are much better castings than OEM so that is also something to consider. If I was Daddy Warbucks TFS would prolly be sittin on top of my motor
Old Aug 3, 2008 | 01:21 PM
Kingc8r's Avatar
you can make big power but you are limited to only a few options such as the MS4 and TFS heads people have suggested
Old Aug 3, 2008 | 02:09 PM
BriancWS6's Avatar
When it comes to extracting this much power out of a 346, more than just cam and head selection comes into play. Attention to detail is very important. Having high quality supporting components will play a major role in the final outcome of the combo.
