ls1howto down?
Old Jul 30, 2008 | 08:12 PM
Kurtomac's Avatar
Default ls1howto down?
big day is tomorrow...going to install my HCI on my 02 z06 and was going to print the instructions tonite on ls1howto.com....but the website appears to be down....hopefully it hasnt **** the bucket....cuz i dont really know how to remove the rack n pinion steering
Old Jul 30, 2008 | 08:57 PM
deadhorse66's Avatar
Why do you need to pull the rack and pinion?
Old Jul 30, 2008 | 10:34 PM
Crowder's Avatar
amen i was thinking of doing my cam this weekend just needing to look at how its down and some torque specs
Old Jul 31, 2008 | 06:11 AM
Kurtomac's Avatar
cuz its a vette....ive done 3 hc swaps before....just like that write up for tq's and this is my first on the vette so i wanted it
Old Jul 31, 2008 | 06:17 AM
Engine_HP's Avatar
hey man wish u luck... take some pic lets seee..... make sure every thing is clean be4 installing......
Old Jul 31, 2008 | 06:42 AM
BlackScreaminMachine's Avatar
Internet Mechanic
its not a bad job get the proper diameter aluminum dowels and cut them to about 2 and 1/2 feet. Oil them up and insert, when removing the cam.
Old Jul 31, 2008 | 09:33 AM
Kurtomac's Avatar
dont have to worry about this....doing heads and cam...so I'll be removing the lifters
Old Jul 31, 2008 | 10:19 AM
Dragkid1917's Avatar
FOr the guy whoos just doing the cam swap... 5/16 dowel... like 2 feet long, maybe a bit longer to play it safe. Lube it up before you put it in the block.
Old Jul 31, 2008 | 12:22 PM
I still don't see what this has to do with changing heads/cam. The most you will have to do is pull the intermediate steering shaft off of the gear for clearance.
Old Jul 31, 2008 | 01:16 PM
BuffJoeyD's Avatar
Yes, the site seems to be down- best bet is just to go to google , type in Ls1howto and cam , and make sure you click the Cached link, it will load up that way just fine.
Old Jul 31, 2008 | 01:39 PM
Johnnystock's Avatar
youre a genius!
Old Jul 31, 2008 | 05:04 PM
01ssreda4's Avatar
edit...ok i figured it out.
Old Jul 31, 2008 | 07:24 PM
Kurtomac's Avatar
no the rack needs removed....it is directly in front of the balancer
wish i had my fbody back...those are cake...this sux so far....3.5 hrs deep
Old Jul 31, 2008 | 07:57 PM
itchygomey98's Avatar
Yea, When my buddy wanted to do a cam in his vette I took one look at it and knew it was gonna be no fun compared to the f body.
Old Aug 1, 2008 | 12:56 PM
Gotcha. Good luck, man. If you need some torque specs, I can get them off the GM site for you.
Old Nov 22, 2008 | 10:26 AM
prochargedchevyi's Avatar
I'm going to revive this thread....
What's going on with LS1howto.com? Have they closed the doors or what? Just tried going onto their website and it's forwarding me to a generic page.
Old Nov 22, 2008 | 02:20 PM
Speed Density's Avatar
hashtagBMW
Yep its down, looks more perminant then temporary right now. Ive tried contacting jmX and cant get ahold of him.
Tony.
Old Nov 22, 2008 | 04:11 PM
99blancoSS's Avatar
Tony.
Panic fills the air...LOL
If you need help post up, more than one person on here have done a few
