car takes forever to return to idle
Old Aug 11, 2008 | 07:50 PM
byler900f's Avatar
Default car takes forever to return to idle
hey guys. I installed a cam in my car about a year ago and ever since then when you push in the clutch or put the car in nuetral, or even when you stop...it takes the car several seconds to return to idle. it's annoying as ****! i was just wondering if anyone had a similar problem/experience. is there any fix for this??
Old Aug 11, 2008 | 08:13 PM
DaddySS's Avatar
Post over in the PCM section. Throttle cracker or follower decay rate will usually fix this issue.
Old Aug 11, 2008 | 08:30 PM
HavATampa's Avatar
Just like DaddyDoubleS said, do a search for "cracker" (sounds racist) in the PCM section. Also search for "hanging idle". This could also be caused by an improperly adjusted TB set screw messing up your TPS values. Hope you have access to HP Tuners or Edit. Here's a link that'll get you started:
https://ls1tech.com/forums/showthrea...ferrerid=13535
Old Aug 11, 2008 | 08:45 PM
byler900f's Avatar
ok thanks guys! unfortunatly i don't have access to hp tuners or any editing software. i have really been considering making that purchase.
