I'm contemplating going with a 427ci
Old Feb 12, 2003 | 05:03 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Default Re: I'm contemplating going with a 427ci
I reccomend staying at 4.000 stroke for most folks.
I think I would budget around $7500 for the shortblock.
You can get your heads redone to to accomodate the increase in bore.
I had a LS6 head'd 422ci ironblock and dynoed 472rwhp/505rwtq at Speed Inc. I ran 1.75 headers.
Old Feb 12, 2003 | 05:57 PM
Mark IXZD 150's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Pro Stock John:
<strong> I reccomend staying at 4.000 stroke for most folks.
I had a LS6 head'd 422ci ironblock and dynoed 472rwhp/505rwtq at Speed Inc. I ran 1.75 headers. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">John, you were a big help when I was configuring my current engine. Thanks again!
I have to be able to honestly say it's a "427". Why do you suggest a 422? It's close but I have some other appearance ideas related to a 427 moniker. Reworking my current heads is a good idea and will hopefully save some money. They're currently milled to 10.8:1 Should be okay right?
I also want to reuse my headers, LS6 intake manifold, ported oil pump, ported TB, valve covers and fuel system (with bigger injectors) which should be no problem.
Does ARE use the Darton sleeves?
Old Feb 12, 2003 | 09:00 PM
Muscleshop's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Muscleshop:
<strong> </font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Mark IXZD 150:
Does ARE use the Darton sleeves? </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">As far as I can tell, ARE uses "special" sleeves made by Darton. Not sure what the difference is between the "special" made sleeves and the regular Darton sleeves???? Maybe someone else can answer this for us? [/QB]</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">
Old Feb 12, 2003 | 09:31 PM
Jimmyz's Avatar
I recently took my car to Lamar Walden Automotive {770-449-0315} in Doraville, GA. They performed some VERY necessary surgery on my car w/tuning. I strongly recommend them.
They are currently building a C5-R aluminum 6.0L 427 for someone wanting a late model ZL-1 style camaro. I'm sure it ain't cheap at all but maybe worth a phone call.
Ask for Rob and tell him I sent you. You MUST see his business for yourself if you're looking for MORE power.
Old Feb 12, 2003 | 09:34 PM
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Jimmyz:
<strong> I recently took my car to Lamar Walden Automotive {770-449-0315} in Doraville, GA. They performed some VERY necessary surgery on my car w/tuning. I strongly recommend them.
Ask for Rob and tell him I sent you. You MUST see his business for yourself if you're looking for MORE power. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Georgia isn't exactly in my neighborhood... <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Old Feb 12, 2003 | 09:57 PM
Ron@Vengeance's Avatar
Ask for Rob and tell him I sent you. You MUST see his business for yourself if you're looking for MORE power. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Buhahahaaha....Look whos on whos dick now JimmyZ....lmao.... <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
Old Feb 12, 2003 | 10:37 PM
Chicago Crew UnderBoss's Avatar
PRO STOCK JOHN:
Kindly explain why you don't recommend using a 4.125 crank and sticking to a max of a 4.00 crank in a 427 application, like the one MTI is currently build me (4.060 with a 4.125 crank).
Thanks,
MTI 427 Roadster
<small>[ February 13, 2003, 08:09 AM: Message edited by: MTI 427 C5 Roadster ]</small>
Old Feb 13, 2003 | 12:26 AM
Nasty N8's Avatar
SLP does not make 1 7/8 they are 1 3/4. We are going to test some custom 2" on our 427.
Nate
Old Feb 13, 2003 | 07:25 AM
Jimmyz's Avatar
<strong> </font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Jimmyz:
<strong> </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Georgia isn't exactly in my neighborhood... <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Oh...but Toronto or Texas are? <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" /> I didn't realize you wanted somone in your "neighborhood",
my bad.
Old Feb 13, 2003 | 07:44 AM
my bad. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Well, I'd be ordering it and installing myself. I guess I assumed I'd have to bring my car down to the guy in Georgia. If I went that far, I'd drop it off at GMMG in Marietta.
Old Feb 13, 2003 | 09:45 AM
LS1Tech Co-Founder
The more stroke you run the more the car will have monster torque.
I think for a street car that will rarely see the track I would try to keep the stroke down.
I was making 500 ft lbs of torque by 4200 rpms, ever seen someone spin 28" slicks for a block. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Feb 13, 2003 | 09:54 AM
  #32
Fulton 1's Avatar
I have some other appearance ideas related to a 427 moniker. </font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Mark, my plan is to do a 427 within the next couple of years and I've also wanted to get hold of a subtle moniker like you mention when the time comes. I'm thinking of a 427 decal in similar font and color to the old 67-69 BBC Corvette hood emblem (see below). These would go on either side of my raised SS intake. Is this something you would make/sell? Please drop me an email or PM if its something you'd be interested in.
Thanks,
Joe
<img src="http://greenwoodchevy.com/Merchant2/graphics/00000001/3900325-6-7.jpg" alt=" - " />
Old Feb 13, 2003 | 07:55 PM
  #33
Jimmyz's Avatar
<strong><snip> Well, I'd be ordering it and installing myself. I guess I assumed I'd have to bring my car down to the guy in Georgia. If I went that far, I'd drop it off at GMMG in Marietta. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I'll leave that one completley alone.
Good luck. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Feb 13, 2003 | 09:40 PM
  #34
DONAIMIAN's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif"> The more stroke you run the more the car will have monster torque. </font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Torque is fun as hell on the street, especially with a set of gears, and a girl in the passenger seat to scare the **** out of <img border="0" alt="[evil]" title="" src="graemlins/gr_devil.gif" />
Old Feb 15, 2003 | 01:17 AM
  #35
ISPEEDWS6's Avatar
JIMMY Z....
You can rip on any one of the shops(three or four) you have spent money at all you want...
But don't think for a min. I'll let you bash me...
If you don't have confidence in my work or knowledge, then take my cell phone number out of your speed dial.
I've kept my mouth shut , but i got to tell you i wouldn't be so proud of those numbers and Lamar, considering i can make that with a slip and slide cam and no tuning thru CATS no less...
Anyways my point is you can recomend anyone you want, you can bash anyone that you think you have a beef with... but i never treated you with anything but professionalism and general friendship. I don't appreciate public comments bashing GMMG or my work, funny how i'm your best friend when you need something....
....glad i have caller I.D.
Best of luck with your lead sled...
