How many miles are Comp 921's good for?
Thanks.
Anyways sorry that wasnt to answere you were looking for. I would say either check them, or just get new ones.
I like the 918s and now the 921s very much. light wt and Not too strong.
my only driving is on a road course with constant 3000 to redline 6700.for 20 to 45 min at a time, 3 to 4 times a day, two days every month.
My cam is a 224/224 581/581 112 on a LS6 with polished LS6 heads. and I do use sodium filled valves.
Too much spring effects valve seat pressure and release.
Just look up the specs for the springs, i'm pretty sure its 135 lb. @ 1.770 and 400 lbs. @ 1.220. I would double check though this is just off the top of my head if i remember right. So you just compress the spring to those hights and measure the lbs of force its makeing. that will tell you the condition the spring is in.
