X1 Cam and Ported LS1 heads
There are several vendors on here that can provide you with a kick *** set of heads for a reasonable amount of money. Joe Prince just released a STG1.5 head that would put you well into the 400's. Many of the vendors here should have you into the 430rwhp range with their STG II heads- all for under 2k.
I don't believe that you really need the bigger 2.055 valves unless you're going with bigger cubes. People have been getting excellent results with the 2.02/1.57 combo. You just need a good quality valve and proper setup.
The X1 is not that big of a cam by todays standards so call around and the sponsors will be more than willing to hook you up.
As I stated earlier- stay away from "locals". Go with a tried and true head that has been around the block and you know works. Take a look at the right, and start calling around. Talk to these guys, tell them what you are trying to do, and they will hook you up based on your budget.
I have talked in length with Brian @ TEA, Jay @ Absolute and Joe Prince. All of them are great guys and when it comes time for me to buy a set of heads, it will be a tough decision, but one of them will be the way I go.
There are so many head porters sponsoring this site that will give you great flow and velocity for very little money. On a stock bore, anything over 2.02" intake valve hasnt really shown to be helpful.
If you are going to be going through a headswap, make it worth it and give a few bucks to JPR, Absolute, Patriot or whoever a search on this board shows gives consistent results with stage 1 packages. I see post all the time by folks who are very pleased with stage 1 results.
Also, the MTI X1 cam is a serious power player, and is really good in a HUGE variety of situations. I have it in my 387, Jayson of MTI fame put it in his 427, and it seems to never fail to make excellent power in stock cube scenarios whether with head porting or not. I will warn you though that it does make the valvetrain quite a bit louder. For many, this is no big deal. Any cam that has serious ramp rates will likely do this.
Good luck, and let us know what you decide.
chris
