LS6 valve overall length?
Old Aug 19, 2008 | 12:59 PM
Mike96z's Avatar
Default LS6 valve overall length?
Doing some research, I seen that not all LS6 valves are the same length. 01 valves are 0.6 mm shorter than the 02 valves.
Does anyone have the exact lengths as well as stock LS1 valve length.
The difference in length of the valves for LS1 is because the 01 cam had bas circle of 19.3 mm and the 02 cam is 19mm.
thanks
