Cam Timing ???
Old Aug 23, 2008 | 12:47 PM
LSXRX7's Avatar
Default Cam Timing ???
can i degree my cam with the heads on? when im doing this with the weak check sprigs i get 17 After TDC @ .50 lift when my cam card says 6 before TDC....
Old Aug 23, 2008 | 02:09 PM
JPH's Avatar
JPH
Shes either way retarded or you doing something wrong?
Old Aug 23, 2008 | 02:14 PM
vettenuts's Avatar
Are you using the intake centerline method? Did you get TDC at the crank set correctly?
Old Aug 23, 2008 | 03:03 PM
LSXRX7's Avatar
no my cam card does not have intake centerline num (MS3).. and yes its at tdc corretly..
Old Aug 23, 2008 | 03:16 PM
JPH's Avatar
JPH
Aslong as your not preloading the valve springs for 0 lash, and the lifters not absobing the pushrod/dial indicator setup as you roll it over to .050, it should read close to 6* (+/-) .5* or so. Or cam is ground incorrectly.
Old Aug 24, 2008 | 02:40 AM
LSXRX7's Avatar
hmm im lost cause when its at 0 lash the timing is futher off.. retarded.. but with the rocker torqued down its less.. <-not sure if thats the way to do it but??? I advanced my cam gear 2 teeth and now @ .50 lift im at 0* TDC. that does not seem corect to me for the cam to be that far off..
