Yella Terra wipe pattern?
Old Aug 27, 2008 | 07:58 PM
gtorep's Avatar
Default Yella Terra wipe pattern?
Guys, im setting up my new rockers with the heads off the car and have run into a bit of a issue. Is it normal to have un-even wipe patterns? With both rockers installed with no shim the exhaust has a perfect center wipe, while the intake wipe is slightly towards the back of stem? with the shim they are both towards the back? Has anyone had issues with this?
Ive set them up using the theories in this thread and they are being used on a AFR head https://ls1tech.com/forums/generation-iii-internal-engine/970338-would-yella-terra-worth.html
Old Aug 28, 2008 | 01:05 PM
gtorep's Avatar
Nevermind the ink was drying to fast and thick, screwed up the whole pattern
Old Aug 28, 2008 | 01:41 PM
vettenuts's Avatar
I found it best to get everything set and then put the ink on and wait about 30 seconds and check. I found if left to dry the check springs didn't do a very good job of wiping a pattern.
Shoot some photo's of your results.
Old Aug 28, 2008 | 02:36 PM
Michael V's Avatar
I just set up my 205's about a month ago. I used a .062" thick washer from Loews. The ID was 3/8"
I took a mic with me and measured each one to ensure they were within .001". My wipe was not the same from intake to exhaust, you just split the differance. On another note, I used 7.500 pushrods. I think you'll find that is what is needed. If you have any more questions on this setup, send me a message.
Mike V
Old Aug 28, 2008 | 04:04 PM
ssmith512's Avatar
Yella Terra's rock!
Old Aug 28, 2008 | 08:51 PM
dz999's Avatar
Exclamation
I used a dry erase marker rather then a permanent ink marker; it made it much easier. I ended up with 0.090 spacers to get a narrow centered wipe pattern. I got the shims from McMaster Carr.
