engine swap
Old Aug 31, 2008 | 10:18 AM
spaulsen's Avatar
Default engine swap
i have a 98 z28 that im swaping the ls1 with a lq4 and 4l80e. was woundering what harness i would have to use. also i have heard that the 98 ecm is not the most desireable ecm to use. i have read that when changing from a 4l60e to 4l80e you have to use the bfh mod to the trans tunnel but how extensive of hammering is it? also the article said u have to cut the ears off the trans. anyone have any pics of this or know where i can find the info? also will i need to change the fuel pump? any help would be appreciated. thanks, shawn
Old Sep 1, 2008 | 01:03 PM
spaulsen's Avatar
free bump
Old Sep 1, 2008 | 10:13 PM
SOMbitch's Avatar
I am sure the driveshaft length is different but THINK (about positive) it will fit with no BFH. I also think as long as it is an E it will work on your 98 pcm. I have not done this swap though so i defer to others with more hands on knowledge.....
Old Sep 1, 2008 | 10:15 PM
m8w6r77's Avatar
doesn't the grey plug that hooks up to the trans has a different pin outs on the 60e and the 80e?
Old Sep 2, 2008 | 02:02 AM
Red96TA's Avatar
Do a search on 4l80e swap and youll come up with a thread that has tons of info that is very helpful. I believe it is title "Everything that is needed for a 4l80e swap"
