Cam ???
Old Sep 4, 2008 | 02:20 PM
70ls1chevelle's Avatar
Default Cam ???
I have a 5.3 engine with a comp cam in it,will that same cam work in a 6.0 ???
Do the 5.3, 5.7, 6.0 take the same cam?
Old Sep 4, 2008 | 03:27 PM
LS1Formulation's Avatar
They will all work in a Gen III engine, but your powerband will move down the RPM scale. You'll make more torque down low and less horsepower up top. You're adding roughly 40 cubic inches going from a 5.3 to a 6.0, so to keep the powerband similar, you'll have to step up the duration on the cam 6-10 degrees.
Old Sep 4, 2008 | 09:42 PM
Jason 98 TA's Avatar
LS1Tech Premium Sponsor
Definately be careful selecting a camshaft for that 5.3l engine. I've seen way to many people kill low end power putting a improperly setup cam in a smaller motor like the 5.3l. We stock several different comp cams for the 5.3l engine. Give us a call & tell us more about your mods & we can help choose a camshaft that's right for you!
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
