guestimate how much WHP this would be?
Old Sep 7, 2008 | 01:41 PM
2KnbmTA's Avatar
i would go with tsp headers. you can get 1 7/8's for like $480
Originally Posted by toneloc60
Define "big difference" and then please show me dyno results that would support that claim.
I wouldn't bet on anything more than 10-15rwhp difference across the lineup of all longtubes with the same primary tube diameters.
Old Sep 10, 2008 | 10:00 AM
5.7LRX7's Avatar
The setup I am looking at running for my car will be as follows tell me what you guys think she will make.. Remember im trying to keep the stock driveability but add more power.
stock short block
LS6 intake and bored TB
LS6 camshaft
Patriot stage 2 heads
full 1 3/4" headers to 3" collectors to a single 3.5" exhaust system (remember im a rx7)
cold air intake system
complete dyno tune
yes not huge mods and i know you guys will be like use a better cam!! i would but im not lookin for much over 400whp.. so what ya guys think that setup will pump out?
Old Sep 10, 2008 | 10:11 AM
00pooterSS's Avatar
stock short block
LS6 camshaft
complete dyno tune
Dont think you will hit 400 with that cam, probably closer to 370-380, look at a 224 with around 56x.-57x lift that would be very very similar but give you more powaaz.
you can have drivability without big bad cams and still get that 400 mark, even without the big bad heads. the heads are a little overkill for what you are trying to do, but for the most similar to stock and 400whp your proposed setup would probably be best.
just for reference I also want about 400rwhp and I am going to do it with a 228 cam/ LS6 intake/ and (used Z06) LS6 heads. The 228 is supposed to still maintain real good drivability and street manners.
Old Sep 10, 2008 | 11:03 AM
5.7LRX7's Avatar
arnt the ls2 heads direct bolt ons to the ls1?
Old Sep 10, 2008 | 11:15 AM
johnLs1camaro's Avatar
i think but you would need a ls2 intake manifold also
Old Sep 10, 2008 | 11:20 AM
streetassasin's Avatar
Old Sep 10, 2008 | 11:39 AM
Jason 98 TA's Avatar
LS1Tech Premium Sponsor
360 is possible, but I honestly don't expect a lot of power from the rockers. 1 7/8" headers will make a little more peak power, but they will really shine at bigger power levels. The ls6 cam idea isn't bad, it cost about the same as a set of rockers & will gain 10-15hp!
If your feeling like running a little bit more camshaft, the TSP 224R made 70hp gains on the stock heads!
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Old Sep 10, 2008 | 12:50 PM
5.7LRX7's Avatar
hmm choices choices everywhere!! which route to go.. i wish i had about 5 grand to drop in it id just supercharge and forget it!
Old Sep 10, 2008 | 01:33 PM
00pooterSS's Avatar
LS2 heads are 243 castings which are Z06 heads but do not have the lightweight valves that the Z06 versions do, and thats what you want if you are going to do budget heads is 243 castings, just make sure they are 243 castings if you buy them. So to answer the question yes the LS6 intake & heads bolt right up.
Old Sep 10, 2008 | 01:48 PM
5.7LRX7's Avatar
but then how much power will it net you with all being stock? also what would the max lift be on the ls2 heads stock?
Old Sep 10, 2008 | 01:53 PM
00pooterSS's Avatar
no comprendo essay
