02 zo6 cam?
Old Sep 4, 2008 | 11:34 PM
danny03cobra's Avatar
Default 02 zo6 cam?
Hey guys i have a c5 z with vararam intake and a catback, i will do full exhaust and i need opinions on a cam. I dont want something that iddles really rough or is not street friendly, the car is daily driven and i want some more ponies out of it.
Thanks
Danny
Old Sep 4, 2008 | 11:55 PM
Summerwolf's Avatar
search is your friend
the general consensus is to swap in a cam that is worthwhile and a ton of people recommend the TR224
Old Sep 5, 2008 | 12:01 AM
is that the same as 224r from tsp? iam new to the chevrolet engines, i have had several 600-high 700 rwhp cobras. I want to build something fast and street friendly with my z. Thanks for the info
Old Sep 5, 2008 | 12:19 AM
Summerwolf's Avatar
http://thunderracing.com/
Its a good middle ground cam, some people step up to the 228 if they want a little bit more power. Just do some research and have fun with the car! The main issue I've seen with people and cams is that they go too big out the gate and want smaller, or too small and want bigger....just do research so you only have to do the swap once.
Old Sep 5, 2008 | 12:25 AM
Thanks bro.
Old Sep 5, 2008 | 02:50 AM
180ls1's Avatar
if you dont have emissions i would go with a 228/228 or patrick's 228/232 he is a sponsor on here. Both will drive awesome and not give you surge problems and should easily put you over 400rwhp.
Old Sep 5, 2008 | 03:01 AM
MLP00Z28's Avatar
Get a look at some lingenfelter cams, some of them have really shooth idles and thunder racing cheatr cam also has a high lsa, both are perfect DD cams
Old Sep 5, 2008 | 03:14 AM
Summerwolf's Avatar
you'll get a million answers, just do the research and choose what you think is right for you after talking on here, researching, and possibly calling up a shop....
Old Sep 5, 2008 | 06:34 AM
87silverbullet's Avatar
Everybody has a different definition of fast so I have a friend of mine with a frc vette with just a TR224 and full exhaust and stall and it runs 12.20 all day. He drives to work with it every day 50 miles one way with no issues.
Old Sep 7, 2008 | 03:11 AM
Thanks for the replies guys.
So the LS6 motor responds really good to longtubes and a cam is what i hear, any more info for me on the motor would be greatly appreciated.
Hey guys i added a vararam coi on the vette and i keep getting a check engine light, p0174 left bank running lean?WTF? is that common?
Old Sep 7, 2008 | 03:27 AM
Summerwolf's Avatar
Make sure your MAF is plugged in/all your clamps are tight. I know I sucked some water up in my intake and it screwed the MAF up and I threw that code (along with several others)
Did you disconnect the negative terminal for 15 minutes? If not you could try there and if it continues you might have another issue.
Old Sep 7, 2008 | 09:23 AM
user 70810891082's Avatar
I have your car. Click on my sig to see the cam route I took.
..and Vararam's almost always throw up a CEL. A tune will fix it.
Old Sep 7, 2008 | 04:16 PM
i did disconnect the negative cable when i installed it, and once in a while i get the light again.
Old Sep 7, 2008 | 04:17 PM
you dont have a video of your cars idle do ya?
Old Sep 7, 2008 | 05:31 PM
Click on my sig.
Old Sep 7, 2008 | 08:55 PM
00pooterSS's Avatar
I would recommend a 228ish duration cam for your application if you dont want to lose good overall drivability stay away from under 224 duration cams ( not that much gain in it ) and I would stay away from high 230's and up duration cams also as they are generally for higher RPM power. If you want a smooth idle you will have to stay at 114 or higher on the LSA ( lobe seperation angle )
I would say a 228ish to 234ish duration range cam with a 114 LSA would be a good place for you to start looking into.
I myself like Texas Speed, you can look at their cam selections and call one of the guys up there they are very helpful and can guide you to a good cam for what you want the car to do.
http://www.texas-speed.com/shop/
http://www.texas-speed.com/shop/cate...MID=3&catid=44
Old Sep 7, 2008 | 09:18 PM
Garrett114's Avatar
I have a TR cheatr cam in my car and love it. Stock like idle with more power. I seen the cam do over 400rwhp a few times and compared to a TR224 cam it dosnt have the low end but up top it pulls away
Old Sep 7, 2008 | 09:40 PM
thanks for the help guys,i would love a choppy idle but i,m in Cali so it wont work. hey are the c5 zo6 heads good enough or do most people change them out?
Old Sep 7, 2008 | 09:42 PM
Click on my sig.
car sounds sick bro!
Old Sep 8, 2008 | 01:29 AM
transwiz's Avatar
I am in California too.I went with a custom grind comp cam 224/224 561/561 @115.I wanted a really good driver car that had a fairly smooth idle.The tr224 and the tsp224r are really good smooth ,drivable cams.The biggest you can go and pass smog,with a good tune is 228/228.(pulls really good,slightly bigger.Yes 114 lsa would be a good place to start.Take your time and read a lot about it before you decide,thats what I did.
________________________
2000 t/a ws6 224/224 cam ,317 heads 62 cc ported polished 2.08 intakes,melling 295,ls2 timing chain,ls6 intake,fast 36 injectors,ported bbk 80mm tb,MTI lid & k&n filter,Kooks lts,kooks hf cats,Magniflow catback, ngk tr55,m6, comp pushrods,h/s rocker bearing mod,etc,etc 408rwhp
