Need advice on handling this situation...
I got lucky this year and 2 of the dealers that have F@#%ed me went out of buissness!!! IF only the one that Stuck it in deep and broke it off would Go Under.... I've ridden in (and driven) this car a countless number of times. Never, since the rebuild, did either of us feel comfortable taking it up to 3500 RPMs. We were told that "it needed tuned". Heck, even when he went for the dyno tune, they wouldn't run it to 3500 RPM there because of the ignition issue...... That "issue" turned out to be 3 different brands/types of spark plugs (all gapped different), 2 different sized spark plug wires, and an electrical fault that was blowning fuses from the melted 02 sensor extensions (that I found melted to the header)..... all installed by the highly trained craftsmen at his local dealership.
So really, what we're looking at is a 2000 mile run, give or take, in which the engine decided to reject oil by some unnatural means, or you have a failed engine due to poor quality work, the likes of which the dealership has already displayed on several ocassions. I'm probably more angry about this than Bill is, which is stupid since I don't have a dime in that car; just blood, sweat and time.
It wouldn't surprise me if they neglected to install new main bearings....
Heck anything more than a quart low after 1k miles is already a serious problem, but if within 2k it's drained off that much oil then I would think that is shoddy workmanship of the people who built that motor.
He never said anything about it not being able to go over 3500 rpms or any of some of the other stuff you just said so now I can see where he is coming from.
But yeah, It's not like I was stupid and just neglected the basics of owning a car. This thing seemed to evaporate out of nowhere. The fact that they reused cam bearings says something!! I didn't know this at the time. Also, I'm willing to bet that their "collapsed lifter" story was a result of the lack of oil pressure. Pressure, as has been stated, that was fine prior to them touching the car.
Go the court route and buy a G8 GXP while you wait. Then when you win go ahead and buy a stroker motor and drop it in the car...
