Comp "R" lifters and YTs, or are stock ok?
Old Sep 5, 2003 | 08:21 PM
SPANKY LS1's Avatar
Default Comp "R" lifters and YTs, or are stock ok?
Do I need Comp "R" lifters and YTs, or are stock ok? My stock rockers and lifters have ~3800 miles on them, only ~400 were with the 230/224 cam, the rest were when the car was stock. My new cam will be big, I guess what I need to know is at what point are upgraded lifters and rockers considered necessary? What are the advantages to the "R" lifters? I know the YTs will not flex any compared to stockers, but not sure about the lifters. Thanks, Shawn
Old Sep 5, 2003 | 10:06 PM
Country Boy's Avatar
Senior Member
Default Re: Comp
The lifters are made for high RPMs as they dont bleed down as much as the stockers. You can run them to 7000 easily (I have).
I wouldnt do the YTs with the Comp Rs though. The Rs like less preload (.010-.020) and not the stock preload (~.050). With the stock rockers or YTs, you cant do anything to adjust the preload except guess with the shims with the YTs. I would do the Comp Pro Mag rockers. The only down side is that the smallest ratio is 1.75, but it shouldnt make a big difference. Its only .05 different from stock.
Old Sep 6, 2003 | 01:33 AM
Colonel's Avatar
Default Re: Comp
Spanky, what cam do you plan to run?
Old Sep 6, 2003 | 08:35 AM
SPANKY LS1's Avatar
Default Re: Comp
G5X4
Old Sep 6, 2003 | 04:05 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Default Re: Comp
I have 1.7 Y/Ts and R lifters, and the motor is built (hydraulic) to buzz up to 7200 and still make power up there. We'll see how it acts above 6800 rpms.
Old Sep 7, 2003 | 11:15 AM
theblur98ss's Avatar
Default Re: Comp
I'm running comp r's with y/t's and no problems yet. My motor isn't supposed to see high rpm but it's been to 7k a few times and still holding together. That's with a .612 lift cam too.
Old Sep 9, 2003 | 12:25 PM
robertbartsch's Avatar
Default Re: Comp
I'm running TY rockers and "r" LIFTERS....no issues...
