Help! Want Cam Suggestions
I'm looking at a comp cams cam swap for ls1. Anyone done it? I have every bolt on, intake and injectors, etc...not broken into engine yet but thinkin on comp cam, I also am interested in gains with this vs. cam and roller rockers? gains for each and both? what kind of roller rockers also?
I took my time and it went very well and it ran great from start-up on. No leaks, no troubles. You can get it done. Just don't rush.... Oh yeah, do an oil pump, too. Be open-minded when you research. I started out thinking I wanted a big MS4 for my car and after "learning" what I could, i went with a TR224 and love it. I would have been way over cammed with an MS4 for my application.
Good luck!!
Don't overcam, you'll be under-impressed
If you are willing to look at other companies that cut cams Isky has been cutting cams for over 50 years. I am running a special right now and you can spec out exactly what you want.
I am currently running one and several of my buds are as well with great results
https://ls1tech.com/forums/generation-iii-internal-engine/983272-brand-new-custom-cam-sale-355-shipped.html
