roller rockers and springs
Old Sep 8, 2003 | 01:48 AM
yobabiesdaddy2001's Avatar
Default roller rockers and springs
what things should be taken into consideration when trying to decided what size roller rocker to use. (1.7 or 1.8's) what role does springs play in this
Old Sep 8, 2003 | 02:25 AM
jaberwaki's Avatar
Default Re: roller rockers and springs
well
do you want it to get more powa or you just want to change them to quiet your valve train?
do you have a cam?
are you planning a cam?
if yes stay 1.7 to 1
if no then 1.8 to 1
depends on how manny miles on the springs you have...
if you got 30000+ it couldn't hurt..
hell if you have 1000 miles it never hurts to go with better springs
hope that helps some
Old Sep 8, 2003 | 08:36 AM
yes Iam planning a cam swap, but the reason i asked was because if you can increase the total lift of a valve with a cam and even more with 1.8 ratio roller rocker together, why not use the 1.8 over the 1.7 . I thought maybe the problem would be valve float, but then thought to just upgrade springs, or could it be clearance that is the problem? thanks for the reply.
Old Sep 8, 2003 | 08:44 AM
HumpinSS's Avatar
Aside from valve float you would probably run into P to V clearance issues and a lot of the cams sold are recommended NOT to be used with 1.8 rockers
