what should i do?
Old Sep 23, 2008 | 07:02 PM
sl99ls1's Avatar
Default what should i do?
ok, well i blew my piston ring in my 99 ls1 z28. I just dont want to fix the piston rings i want to build a stroker. my question is where can i buy a good kit from without spend $6000. and how big (ci) should i go? And im planning on using spray.
thanks for your time jose
Old Sep 23, 2008 | 07:50 PM
conan's Avatar
Are you planing on buying heads and a cam? See sig... with the forged SB, H/C, gaskets/seals, double roller, ported oil pump, comp lifters, clutch, and some other odd's and end's I spent about 8k. Check out texas speed, thats where I got my SB and most every thing else in my sig, They have been top notch to deal with.
Old Sep 25, 2008 | 07:19 PM
sl99ls1's Avatar
is it possible to turn my stock block into a 403ci??? and yes i would be do h/c install if i buy an stroker kit.
Old Sep 25, 2008 | 08:10 PM
RacerXLs1's Avatar
Id say hit up texas speed.They will send you in the right direction.
Old Sep 26, 2008 | 03:10 PM
SOMbitch's Avatar
Possible yes with sleeving but not cost effective. I would buy a forged shortblock from a sponsor and go from there.
Old Sep 26, 2008 | 03:41 PM
99blancoSS's Avatar
Well if you didn't scar up the cylinder to bad then you have a few options. Whats your budget is the first question.
then you can look at different combinations from a short block to just a rotating assembly and having a local shop assemble. So you have options. If you budget is 6k or under you have many options.
