budget 408 heads N/A
Looking to spin around 6800 rpm threw a m6 and 615 lift cam, around 550 n/a hp..
650 lift 111 lsa, with 11to1 comp, i think it will roll hard. I want to see if i can pull575rwhp threw a m6, i might have to go 427 big cam, intake/heads..? I was thinking ported fast with afr 225s but do you think there werth it N/A?
650 lift 111 lsa, with 11to1 comp, i think it will roll hard. I want to see if i can pull575rwhp threw a m6, i might have to go 427 big cam, intake/heads..? I was thinking ported fast with afr 225s but do you think there werth it N/A?Last edited by odarabla; Sep 24, 2008 at 06:24 AM.
http://texas-speed.com/shop/item.asp...d=134&catid=40
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
