troubleshoot codes
Old Sep 28, 2008 | 11:00 PM
97Lt1TA's Avatar
Default troubleshoot codes
my car is running lean in bank 1 and 2. never had this code before does it have to do with the o2 sensors or is it something else.
Old Sep 29, 2008 | 11:01 AM
LS1Formulation's Avatar
It's unlikely both of your O2s would go bad at the same time. Get a fuel pressure gauge and check your fuel pressure at the rail. Sounds to me like your fuel pump may be going out, causing a lean condition.
Old Sep 29, 2008 | 11:06 AM
phoenix305's Avatar
It could also be a MAF problem, but it is most likely to do with fuel pressure when both codes are set like that.
Old Sep 29, 2008 | 03:43 PM
97Lt1TA's Avatar
i will change the pump i was going to put in a walbro 255 pump either way. hopefully that will solve the problem
Old Sep 29, 2008 | 06:12 PM
97Lt1TA's Avatar
i read the codes and the 2 codes that came up are PO174 bank 2 running lean.
i did research and people say its either the maf, fuel filter clogged or fuel pump.
im going to put in my walbro 255 pump that i had in my formula and change the fuel filter and see if that solves the problem
