New setup
Tfs 215's milled to 61cc w/ .040 cometic head gasket, harland sharp 1.7 rockers, pat g custom spec cam, fast 92/92, asp ud pulley, melling oil pump. still to come 42lbs injectors, and undecided on a clutch yet. I was wondering about your rockers, they look like non adjustables. Correct? If they are , could you give me some advise on how to determine the proper procedure on how to setup the rockers/ pushrods. I need shorter length from the 7.5's that i bought due to the milling and gasket. How did you adjust yours, or did you just install and torque the rockers dow to 22ft lbsand call it a day?
