Rocker Arm Question!!!
Old Sep 30, 2008 | 04:23 PM
COJO_24's Avatar
Default Rocker Arm Question!!!
Does a stock LS1 come with rocker arm pedestals or whatever they are called? and what happens when you dont have these?
Old Sep 30, 2008 | 04:38 PM
5.3LJimmy's Avatar
Yes they have a one piece aluminum rail that acts as a pedestal for all the rockers. If you install the rockers and torque them down w/o the rail it will cause all the valves to hang open, and may also cause piston to valve contact if you try to run the engine that way.
Old Sep 30, 2008 | 04:44 PM
COJO_24's Avatar
Ok well that solves a major problem and also creates a major problem at the same time....damage wise
maybe
thanks for the help tho. thats all i needed to know
