Cam for 427 A4 street machine
Later, Mike
GO FOR THE GUSTO! YOu won't be dissapointed and GOD BLESS You for your EFFORTS in IRAQ on behalf of our COUNTRY!!
Later, Mike
Later, Mike
It always an subjective thing as to what is smooth or streetable for one guy vs. another. That being said, i would suggest that the cam is quite smooth as long as tuned by a PRO like JASON at MTI who did mine, who you could get a computer tune via the mail from. IF you are concerned with the 112 then MTI can custom grind this exact cam for you on a 114 lsa and it will idle like stock. I like a bit of hot rod lope and its PERFECT for me and NEVER STALLED ONCE ON ME but i am running at Yank 4000 stall which helps b/c of vacum created by the larger converter.
I say go for it and go 114 if you want a more conservate idle. This cam should make max power around 6200 rpms.
I am told it will be near the same as my 224/224 114LSA I run in my 346 as far as idle and lope... guess we shall see
Dude, the S1 MTI cam in its original specs of 244/244, .612 lift on a 112lsa is a very aggressive street/racing LSX cam and is perfect for a 422 LS1/6 Cid, bad *** street aplication (especially in a A4 car). This cam is a PROVEN performer as its the exact cam that powered the COLONEL 9 sec N/A MTI 422 f-body and NINEBALLs Cannibal Car when he owned it, good for solid 10 sec. time slips (on motor).
As MTI is currently finishing the completion of my C5R block Z07 427 motor as we speak (its being dyno tuned tommorrow
) i inquired with the owner, JAYSON, about going any larger for more power and he told me anyting larger in a hyd. application starts "To reach the point of diminising return."Talk to a few experts yourself like the MTI crew or thunder racing, ARE, LGM, etc. and see what they have to say for what your use and application will be. Trust me when i tell you the S1 should be PLENTY of cam for your 427 street driven A4 car!
Good Luck and get home safely!!!!!!!!!!!!!!!!!!
Later, Mike
Later, Mike
Later, Mike
Well, I read in (I know, I know) the GMHTP article about More Perf 427 build up that they picked up 40fwhp going to their stepped 1 7/8-2" headers.
During my research, every shop I spoke with said 1 7/8" are the best for a street type stroker with a hyd cam and other normal parts like your motor.
Go with the Grot 1 7/8".
As far as the S1, it does sound like it may be the best right now, but I remember when everyone was saying that 224's was the limit for 346's.
How on earth could that go into a 346ci?
I think you're gonna be unpleasantly surprised when it shakes your fillings out if you're putting the S1 in a 346. Will it even work in a 346?
