Question on timing?
Thanks
Jon
Cleaning pistons is easy, just be careful you don't nick them with anything sharp. Put the piston to TDC and use Brake Cleaner and/or Gumout to soften the carbon and scrape it with a razor blade or small scraper. Use a vacuum to suck out all of the carbon pieces as you scrape to minimize the mess.
...use paper towels and silicone spray when cleaning ...do nto get any loose carbon in between the rings and pistons...
