Affordable Jesel ADJUSTABLE rockers
This is the discription for the adjustible Jessel rockers - these are a FULL shaft rocker running accross all 4 holes! Price is $695...
I'm not sure if they require the valve cover spacers or not????
See SDPC ---------------------------------->
Corvette LS1 1.70/1.70 SS Series Rocker Arms
JESEL, the premier manufacturer of shaft-mounted aluminum roller rocker arm assemblies has just release affordable SS Series (sportsman series) shaft-mounted adjustable rockers, eliminating the need for expensive rocker studs, guide plates, polylocks and stud girdles. They bolt on to existing rocker stud bosses without need for machining and provide a rigid base for the ultimate in valvetrain stability and correct rocker geometry. Jesel’s SS Series rockers are supported by a patent-pending, CNC machined steel alloy Stand-LinkT, positioning the individual rocker stands for precise alignment with the valve tip.
either SDPC has their info wrong or Jesel told me the wrong thing.....
