Differences between 241 and 243 stamped heads?
EDIT: the search button kept giving me a "NET server error" so I couldn't search.
243 are 2001 (I thought) and newer LS6 heads, as well as LS2 heads. Typically the LS6 heads had sodium filled light weight valves and 64cc chambers. LS2 had standard valves and 64cc chambers.
The 243 heads flow better then 241 head when stock. If they are modified (ported) then it is a different scenario.
241 heads came on mid-00 through the 02 fbody cars. if a 2000 car got 241 heads, it also got the ferrul-less (stronger) rod bolts.
243 heads have a smaller combustion chamber (but offer the same ptv) and flow better than the 241 heads. they also have lighter valves. they are worth roughly 15whp on an m6 stock 10 bolt setup.
"Here's a secret: If you want the best heads for performance, make sure your heads have these small triangle marks below every spark plug hole. The marks are left by "chills" used during the casting process in GM's semi-permanent mold (SPM) tooling. Of the three casting facilities that make Gen III cylinder heads, two use SPM tooling, the other heads are sand-cast. The SPM tools produce heads with very smooth, consistent ports and chambers which consistently dyno at least 4 to 7 hp better than the sand-cast heads. "
Source: http://www.carcraft.com/techarticles...ads/index.html
http://web.camaross.com/forums/showthread.php?t=410492
But also say that Sodium filled exhaust Valves, Titanium intake valves and Ti retainers are just more expesive then Stainless steel and no performance difference too.
I thought light wt valve trains were for above 6200 rpms ?
Will it make or break a engine combo, no.
I attributed the potential power increase to a valve train weight theroy and that it is important to get the best out of it, but if you got your hands on a set of 243's w/o the Triangle in the casting, it isnt the end of the world.
-Mark
