L92 info?
Old Nov 24, 2008 | 03:07 PM
tr_racing's Avatar
If I want to put headstud & rod bolt from ARP which one will fit, the LS1???
Also does someone have the LS7 lifter part number??
Thanks!
Kevin..
Old Nov 24, 2008 | 03:16 PM
sroach20's Avatar
you need the one for 04+
Old Nov 26, 2008 | 05:41 PM
tr_racing's Avatar
If i put a L76/LS3 intake does the L92 fuel injectors & fuel rails will fit???
Thanks!
Kevin..
Old Nov 28, 2008 | 02:18 PM
tr_racing's Avatar
Thanks!
Kevin..
Bump!
Also, i would like to know, which starter i have to use with a Manual transmission, does the LS1 will fits???
Thanks!
Kevin..
Old Nov 29, 2008 | 04:48 AM
the_merv's Avatar
Veteran: Air Force
I'm using LS2 Rails and LS2 Injectors without a problem, I had to shim the Rails 1/2" when I mounted them.
