L92 vvt with msd 6012 controller
I know it will run the 58 tooth crank but will it have problems with the vvt?
The 6012 will run the L92 but won't run the VVT.
I will check and see what the default is. I don't think that it's the retard mode. If so then it should run without the controller.
Robin
Without a VVT controller the phaser will stay in the advanced position and give you great bottom end, but will kill 40-50hp or so out of the top end. Itll fall on its face like the old TPI engines did.
Use it with the Factory EFI and gain all the benifits! I would do anything to have a phaser in my truck!!!!!!!
