What are the flow numbers on LS7 heads?
Old Dec 14, 2008 | 09:42 AM
68lemans's Avatar
Default What are the flow numbers on LS7 heads?
I did some reserch and can`t find flow numbers for new gm out of the box complete cnc ls7 heads ?
Also what rocker arm choices are there ? Are the stock gm ones good for 9`s ?? This is a light weekend street car.
Old Dec 14, 2008 | 02:14 PM
DrkPhx's Avatar
I pulled this from searching here:
https://ls1tech.com/forums/generatio...flow-info.html
LS7 Head Flow - 2.200 Int and 1.615 exh. (From GearChatter)
Valve Lift Intake Exhaust Valve Lift
.100" 60 71 .100"
.200" 145 120 .200"
.300" 222 159 .300"
.400" 271 192 .400"
.500" 315 207 .500"
.550" 332 214 .550"
.600" 348 219 .600"
.625" 350 220 .650"
.700" 359 222 .700"
https://ls1tech.com/forums/generatio...00-lift-2.html
Old Dec 16, 2008 | 01:46 AM
kelp's Avatar
The above was measured by RLD
The first two numbers were reversed
Here are some others, I don't know the source:
Lift Int Exh E/I%
0.100 75 26
0.200 158 115 73%
0.300 228 169 74%
0.400 277 206 74%
0.500 307 219 71%
0.600 325 226 69%
0.650 331 228 69%
0.700 302 229 76%
So take several labs for your averages.
