What spark plugs to use on my LS2 setup! Please help ....
Old Jan 22, 2009 | 08:17 PM
BlueDiamond's Avatar
Default What spark plugs to use on my LS2 setup! Please help ....
Hey,
I have a LS2 engine wih the following mods:
Cam: CompCam XER281HR with the recomended products (timing set, lifter kit, rocker arms, push rods, valve springs, retainers, etc ...
FAST 92mm intake
FAST 92 bigmouth throtte body ( cable driven )
FAST XFI Crate Engine Management Kit, LS2
FAST Transmission Controller & harness for the 4L60E
MSD Coils
Ported Heads
What spark plugs wuld you use with this ?
Thanks
Fabian
Old Jan 22, 2009 | 08:55 PM
LS6427's Avatar
NGK TR55 or TR5 (they're identical plugs)
or
AC Delco
.055 gap
Thats what I've been using on my LPE 427ci for a long time, they're perfect. I use NGK.
NICE LOOKING ENGINE MAN!!!!
Old Jan 22, 2009 | 09:28 PM
demarco313's Avatar
yep ngk tr55.. damn that engine looks good
Old Jan 23, 2009 | 02:16 AM
Thanks for the replies ...
I found the NGK at summits store .. but it says it is only for 2005/2006 LS engines.. mine is a 2007 Corvette engine .. will these fit also ?
Any other brand you can recomend or just the NGK ?
http://store.summitracing.com/partde...3+&appfilter=1
Old Jan 23, 2009 | 08:00 AM
anyone ?
Old Jan 23, 2009 | 08:17 AM
405HP_Z06's Avatar
Assuming your running 243 or 799 heads the NGK TR5 is the correct original heat range plug for your engine. If the engine is lightly modified, this heat range is fine. Personally, I prefer Iridium plugs so I would use either a Denso IT16 or NGK TR55IX.
Old Jan 23, 2009 | 08:22 AM
how do you define slightly ? the cam is a race cam and agressive and the heads are also fully portet ... should make nice HP.
Old Jan 23, 2009 | 08:38 AM
405HP_Z06's Avatar
What is the compression ratio? Will the car be driven frequently and in racing events? Are or will you be running nitrous?
Old Jan 23, 2009 | 09:17 AM
it is the stock compression ( stock piston ) ... the car will be driven on street mainly, will not get nitrous.
Old Jan 23, 2009 | 09:24 AM
LS1-450's Avatar
May want to send a PM to 99BlancoSS (sponsor). He's got a new low resistance Iridium plug that may be of interest to you.
Old Jan 23, 2009 | 09:26 AM
405HP_Z06's Avatar
I would run either the NGK TR55IX or Denso IT16 for this application. I'm running 11.31 SCR, Dart 225's, Crane 222/228 cam, FAST 90, Dynatech longtubes, and Crane rockers with NGK 6 heat range plugs (BKR6EIX-11, DO NOT use this part number for your heads, they are a gasket seat for Dart heads).
