LS2 intake question?
Old Jan 26, 2009 | 03:10 PM
Droptoplt1ta's Avatar
Default LS2 intake question?
Can I use a LS1 fuel rail on my LS2 intake if I have the Katech spacer and Oring kit? Or do I need the LS2 rail?
Thanks
Old Jan 26, 2009 | 03:35 PM
smok'nZ's Avatar
MASS seller approved
KATECH says you need ls2 rails
Old Jan 26, 2009 | 03:54 PM
BIG_MIKE2005's Avatar
Or you can run a aftermarket rail with the injector spacer kit, LS1 style injector & make your own rail hold down clips.
Old Jan 27, 2009 | 03:22 PM
Would this FAST kit 54026 help me use the LS1 rail on the LS2 intake?
** Ebay link removed **
Old Jan 30, 2009 | 07:12 AM
I tried to mount my LS1 rails on my ported LS2 intake yesterday and everything is good, but the attachment points are off.
Old Jan 30, 2009 | 08:23 AM
Cause you can't use LS1 rails. You need the (2) kits offered from Katech also otherwise you gotta hack up your MAP harness to extend it & if your using LS1 style injectors the o-rings isn't the same size.
All the information you seek can be found in a quick search.
