ls2 valley cover
Old Jan 27, 2009 | 07:19 AM
Big Bird WS6's Avatar
Default ls2 valley cover
where does the breather tube in the front of the valley cover go?
thanks
Old Jan 27, 2009 | 07:20 AM
or what is everyone doing with it?
Old Jan 27, 2009 | 08:07 AM
rao's Avatar
rao
It goes to the PCV valve which is attached to the intake manifold.
Old Jan 27, 2009 | 08:26 AM
davidws6's Avatar
Default Valley cover connection
Like RAO mentioned if your not running a can. However, if your going to run a catch can, this is what I did.
On my catch can inlet, I have 1 tube from each valve cover. Then I T'd the valley tube into one of the inlets for the can.
I then plugged the other valve cover vents and drilled a 3/8 inch hole in my oil cap.
Then I flared a peice of 3/8 fuel line about 2 1/2/ inches long and glued it into the cap (flare from the bottom up). Then I clamped one of those little breather filters on the end of the pipe. One web site offers this for around $25. I bought the filter from the parts store for about $10..
Old Jan 27, 2009 | 09:39 AM
i am runngin turbo? does that help. should i just "T" it into one of the lines running to the turbo? like intake side?
Old Jan 27, 2009 | 10:31 AM
davidws6's Avatar
Default PCV n Turbo
If ur running a Turbo, I'd run a catch can for sure. Or you could delete the pcv system altogether like some guys do. I thought of that but in running my 454 for about 200 miles, you should see the condensation buildup in the catch can ! If the catch can would not have caught this, it would have been sucked into the intake.
If you do decide to retain the PCV, use a large catch can and yes, T into it prior to the Turbo inlet.
Do a search on here n you'll find some other articles on the PCV system mods.
Old Jan 27, 2009 | 10:37 PM
WhiteRhino's Avatar
https://ls1tech.com/forums/generatio...outing-ok.html
