Fired it up today... 416 Stroker
Old Feb 6, 2009 | 07:24 PM
2001 Pewter WS6's Avatar
Restricted User
Default Fired it up today... 416 Stroker
Pics of the motor are in another thread. The motor fired right up and sounds strong but is a bit too loud. Kooks headers with catted Y pipe and a Corsa exhaust. I will have to find something a little tamer...
http://www.fquick.com/videos/First_f...6_Stroker/7981
No problems other that the tach isn't working but my autometer tach is, so I will have to check into that...
Old Feb 6, 2009 | 07:47 PM
ItsNotStock's Avatar
Sounds great man. You think that's loud? What was your camera guy looking at inside the car (too dark) oil pressure? You definitely need to get us some more videos, and numbers
Old Feb 6, 2009 | 07:59 PM
venom ws7's Avatar
Sounds mean,
are you planning to run it on pump gas??
Old Feb 6, 2009 | 08:03 PM
Restricted User
Yep the oil pressure was at 60psi but the tach isn't working. I will get some vids soon. Still have to bleed the brakes and clutch and a few other little things.
Old Feb 6, 2009 | 08:04 PM
Restricted User
Originally Posted by venom ws7
Sounds mean,
Yep... Sunoco 93
Old Feb 6, 2009 | 08:12 PM
venom ws7's Avatar
Please keep us posted with the numbers I'm thinking about going N/A From TT.
Good luck
Old Feb 6, 2009 | 08:19 PM
10secondZ's Avatar
Dyno Dyno!! Haha, sounds great man and should run even better.
Old Feb 6, 2009 | 08:48 PM
1FASTBIRD's Avatar
Sound's sick bro and can't wait to see those numbers!!!!
Old Feb 6, 2009 | 08:54 PM
allngn_c5's Avatar
Sounds real nice bro !! 12.1 : 1 compression. How many degrees is the timing advanced ???
Old Feb 6, 2009 | 08:58 PM
Restricted User
28* total timing....
Old Feb 6, 2009 | 11:02 PM
RedRallyeZ's Avatar
i love the taz sticker, where did you get that?
Old Feb 7, 2009 | 07:17 AM
allngn_c5's Avatar
I was curious if you were going to have to sacrifice timing to run 12.1 : 1 compression on 93 octane. Glad to hear you didn't.
Old Feb 7, 2009 | 07:25 AM
Restricted User
It is custom airbrushed. Started out as a plain black lid. The carbon fiber is painted on as well...
Old Feb 7, 2009 | 07:26 AM
Restricted User
I ran 93 on my other other 408 at 12.1:1. I ran it as high as 12.5:1 with different heads and didn't have an issue.
Old Feb 7, 2009 | 08:42 AM
30th t/a's Avatar
Sounds wicked Mark. When are you getting it retuned?
Old Feb 7, 2009 | 08:53 AM
Restricted User
I am going to see how far off it is with HP Tuners first. I am not doing anything until spring.
Old Feb 7, 2009 | 04:14 PM
blu byu EH's Avatar
The reason why your tack is now working is because your ls2 conversion kit is defective. You need to cut two wires and switch them and your tach will work. Is it hard to start too sometimes? The two wires that need to be switch are the two outer ones. I hope this helps
Old Feb 7, 2009 | 04:53 PM
NTIMD8's Avatar
Adding a resonator may be enough if you have the room.
Old Feb 7, 2009 | 11:02 PM
Restricted User
It is hard to start as well. I will try that on Monday, thanks for the tip...
Old Feb 8, 2009 | 11:30 PM
SSIRBY's Avatar
sounds really nice. my 408 is gonna be setup like your old except with a beck intake.
