Cooling issues
Old Feb 11, 2009 | 10:18 PM
TinSecondRice's Avatar
Default Cooling issues
My car seems to like to run hot. It was 33 degrees outside the other day and it still was running 216. If I would give it a little gas it would drop down. I could put it in neutral and rev it up, and again it would drop down. If I put the shifter into drive to where the rpms were higher (around 3k) it would drop down to about 190. I noticed today that even when it gets up to 216 sitting still at an idle, I can put my hand on the top coolant line going to the radiator and its hot, but if I touch the one that goes from the thermostat housing to the radiator it is not hot at all. I can hold my hand on it without a problem even with the coolant at 216. It never gets over 216, seems to heat up to that point and not go over it. Does this sound like my thermostat is sticking? Anything you can think of to check?
Old Feb 12, 2009 | 10:52 AM
CamaroSS22's Avatar
The new corvettes from the factory run pretty hot for emission reasons. The high speed fan doesnt come on until 216. It sounds like it may be the water pump though. I would put a low temp thermostat in it and get the fans retuned.
Old Feb 12, 2009 | 11:21 AM
CodeRed2000SS's Avatar
sounds pretty normanl to me. if it never gets over 216 and the fans turn on, everything is good. just check the coolant periodically to see if anything may be leaking.
Old Feb 13, 2009 | 05:43 PM
C-Sicz's Avatar
You could add an external fan control switch to turn them on manually when ever you want.
