heads lifting?
Old Feb 14, 2009 | 05:19 PM
VGLNTE1's Avatar
Default heads lifting?
i noticed my heads have a oil residue around them. I cleaned it off and it comes right back. Its not enough to leak, or even drip...but is it anything to worry about?
Old Feb 25, 2009 | 09:09 PM
VGLNTE1's Avatar
no one?
Old Apr 12, 2009 | 03:30 AM
VGLNTE1's Avatar
anyone?
oil is now all over the sides of the block.....suggestions?
Old Apr 12, 2009 | 08:07 AM
DAVESS02's Avatar
If you can, post some pics. Head gaskets on these will usually start to leak between the lower bolt holes and leave a residue that seeps down the block. Is there any history of the car having gaskets put on it before?
Old Apr 12, 2009 | 08:39 AM
WKMCD's Avatar
What head gaskets are you running?
Old Apr 12, 2009 | 01:06 PM
VGLNTE1's Avatar
this motor is brand new....about 3000-4000 miles on. everything is still fresh.
the gaskets im using are the .60 ones I got from SDPC. I have some new .50's in the garage. Will my CR change to a point I need a tune with the different thickness?
When I bought my motor from them, they said i had -7 pistons, so I bought my stuff to accomodate for those....I ended up with -2 pistons. so I had to buy thicker gaskets. Should I change them out?
I'm sick of smelling burnt out everytime I drive
Old Apr 14, 2009 | 06:59 AM
DAVESS02's Avatar
on a 4" stroker, you'll gain roughly .3 in compression. In a stock 3.622 you'll gain .25 in compression. Not much and shouldnt affect anything unless you're running on the ragged edge. Probably will be better for quench to boot.
