ls1 knock sensors
Old Feb 20, 2009 | 05:57 AM
1a-play's Avatar
Default ls1 knock sensors
can I relocated them to the heads (end holes) on my ls2
Old Feb 24, 2009 | 03:44 PM
Mechryn's Avatar
You can. Thats what I did. No idea how accurate the readings are now. The knock sensors are tuned for a particular location.
Old Feb 24, 2009 | 04:32 PM
Haans249's Avatar
Its recommended to put them on the sides of the block. I'm not sure if they'll pick up detonation being located on the heads. I haven't seen any testing done in particular.
Old Feb 26, 2009 | 12:52 PM
WADDISME's Avatar
It is best to put them where they belong. I didn't put mine where they should have been, now I can't get my oil cooler adapter to fit. Food for thought.
Old Feb 26, 2009 | 03:37 PM
Bouvs's Avatar
You say that knock sensors have to be tuned for its location. Its still alright to take LS1 knock sensors and place them on the side of the block correct? Or is it necessary to get LS2 knock sensors, or is there no difference?
Old Feb 26, 2009 | 04:48 PM
WADDISME's Avatar
You can still use them. You have to get an extension for the wiring because they are not in the same place. I have never hear of them being tuned.
Old Feb 28, 2009 | 11:11 AM
Haans249's Avatar
They can be "tuned" in the PCM by setting their sensitivities. Although there is really no science to it, as no one has any idea how to "tune" the knock sensors.
Old Mar 1, 2009 | 01:39 PM
Bouvs's Avatar
are they threaded at one end? How are they secured in place?
Old Mar 2, 2009 | 10:32 AM
Haans249's Avatar
They're threaded, but you have to either rethread them, or tap the Gen IV block to their size.
Old Mar 2, 2009 | 11:05 AM
Bouvs's Avatar
got it thanks
