LS2 Fuel Covers on a 402
Old Feb 26, 2009 | 12:48 PM
30birdy99's Avatar
Default LS2 Fuel Covers on a 402
I am doing a 402, L92's with L76 manifold. I wonder about the top where it follows the contours of the intake runners. Also if an Fbody fuel line and purge line fit under it or a hole being cut would work. Pictures on an Fbody would be nice too. Will LS2 fuel rail covers fit on this combination?
Old Mar 1, 2009 | 09:15 AM
HSV-GTS-300's Avatar
Not sure about the F body parts underneath, but you can get 2 piece covers to fit the L76 (or LS3 intake if you remove the "beauty/noise" cover).
Clips onto LS2/L76 fuel rail in 4 places.
Mounts onto 4 studs on the rocker covers.
6.0, L92heads,L76 intake.
Old Mar 1, 2009 | 10:42 AM
30birdy99's Avatar
The only problem I see with these is the fuel line exits the center of the left cover.
Old Mar 1, 2009 | 10:50 AM
Another problem is LS1 fuel rails are smaller diameter than LS2/L76 so the covers wont clip onto an LS1 rail.
