LS1 to LS2 PCV routing ???
Old Mar 4, 2009 | 10:45 AM
30birdy99's Avatar
Default LS1 to LS2 PCV routing ???
Ok, I am swapping a LS2 based 402 into a 99 Trans Am. The stock valve cover on the Passenger side doesn't clear the rocker arms. The LS2 top cover also has a vent not equiped on the LS1 setup. Question is, How do I set up the PCV system and what Gm cover might work?????????????????????
Old Mar 4, 2009 | 10:55 AM
405HP_Z06's Avatar
https://ls1tech.com/forums/generatio...outing-ok.html
