LS7 balancer weights question
Old Mar 25, 2009 | 09:54 PM
dsrour's Avatar
Default LS7 balancer weights question
In converting the LS7 to wet sump and replacing the ls7 balancer with a regular corvette one would it make any sense to transfer the factory weights to the new balancer. Does it really make much difference ? I forgot to mark balancer when removing anyway, actually did not realize this was reccommended in manual.
thanks
Old Apr 2, 2009 | 10:21 AM
c5racr1's Avatar
I think you can use the LS7 ballancer, just chanhe the oil pump, timing cover and cam sprocket if needed, Scoggin dickey sell a spacer to use the stock ballencer with the long LS7 crankshaft. The LS7 is ballanced different so you would need to keep that ballancer or go with an aftermarket one. biggest factor is are you cutting the crankshaft?
